shane_3800
- Aug 13, 2011
- 4,223
- 1,798
- 113
- Age
- 35
- Location
- places
- vr commo
Well Holden never ceases to amaze me.
Here is the lastest. The new L77 (bastardised 3/4) engine is in the process of being fitted to my car at the moment.
I get word today that they (the dealer) has changed the camshaft from the L77 with a new L98 camshaft.
Also as outlined in the Techline they have removed the L77 sump and will take the sump from my August 2009 built L98 (last of the L98's) and fit it to the what was new L77.
There are 2 proceedures on the techline one for a 2007, 2008, 2009 VE with the L98 and then there are the 2009, 2010 VEs with an L98. If the L98 was fitted back in 07, 08 and early 09 is says to use the sump, dipstick tube and dipstick etc etc. For the later model VE (so MY9.5 owards) you on need to replace the Valley cover and crankshaft. There is no mention of the need to change the sump.
I've told the dealer that yes my car is a 2007 VE but the engine is a L98 from the MY9.5 series which is why it only takes 7.6ltrs of oil. The earlier L98 had an 8.3ltr sump.
This is just complete bullsh!t that Holden will replace an engine with a new 3/4 motor but pull it apart to swap bits (like sump, etc) because? who f$!kn knows. From what I can gather seeing NO ONE will give me a technical reason why it is imperative to change theses parts (such as if they don't the ass end will fall out of it). It defeats the purpose of supplying a new motor which is covered under a 2 year 50,000klm Holden warranty.
I have reached the point with all this bullsh!t I have had to go through, that I will be publishing all my frustration on the various Motor magazine sites, Youtube and anywhere else it will get coverage. Basically warning people to be wary of the way Holden deals with Mechanical engineering faults. My recommendation would be not to buy a V8 holden ever. They have had so many years to get it right an still can't do it.
I am also in the process of obtaining professional advice in which to take the matter further.
NOTE: I should add though. Except for what appears to be a lack of care resulting in the sump being removed possibly unnecessarly, my local Holden dealer have been great to work with.
Also was told today that they no longer take the motor out through the top of the engine bay. They remove the engine out the bottom. Yep got to pull all the subframe crap, steering, etc etc out to change the engine. What use to be a 2 day job now becomes a week (maybe longer)......
Heres a pic of the so called NEW 3/4 engine minus the sump.
ahahahahah ahahahahahah ahahahahhahahah 1 week ahahaahaha ahahahah try 2 day max
i think the issue might be the difference in cam lift the car is to work with a set cam lift so l98 cam is to be used
the l77 can be set to afm or non afm
there may even be lobe seperation difference's ??? this would cause slight issues with cam sensors and ecu's
