Utter confusion about trans coolers
lout
60
Langwarrin Victoria
i believe they changed around 1998
i know vxii was deep pan but believe vxi and vt was shallow pan
lout
60
Langwarrin Victoria
interesting, good to know
jaikai
53
VH sl wagon
Our VT is shallow pan. Easy to pick the difference by just looking under. Ribs or no ribs.
shueardm
VZ SV6
yup, or even easier on your back, take the dip stick out and read it :)
NeddyBear
Veteran Mountain Biker
Rubyvale, Qld
2004 2.5L Subaru Outback
So that's a No. Since I meant did you remove a standalone cooler like the one I have had from new.
So, it must have be added with all tow bars at dealerships ( and a lot of VT's have towbars , thus my confusion at the self serve wreckers).
The original one in front of the radiator had been replaced several years earlier and I removed that one when fitting the powered cooler.
334,000 ks and still using the original auto transmission but she is a series 2 and has the deep pan as standard. Still pulls the camper fine and planing a few more trips away when the six cooler months start. Plan to keep the powered cooler when we use the VX as our Hot Rod donor vehicle, will have a tow bar but not for towing a camper just the bicycle rack.
exec24
SA
VY Berlina Series 2
My VS had a Factory fitted towbar and transmission cooler, when i bought it. I removed the towbar pretty much straight away after buying it but kept the cooler, which bypassed the one in the radiator altogether. I later found out that it is also the same brand that supply B&M because when had the motor and transmission rebuilt i wanted to get a larger cooler. i released that there the same brand beside the fittings. the new B&M one bought has 1/2 threads, and then i just needed fitting to suit the rubber hose. whereas the factory type had 5/16 barbs already on the cooler
i upgraded to the larger cooler on the VS running the same setup, and bypassed the radiator cooler(to prevent the issues someone mentioned in a above reply) just in case. i then fitted the old VS cooler which is still working fine to my VY sedan and bypassed the radiators internal transmission cooler. im will be upgrading this to the larger type cooler when the VY sedan gets its new engine and transmission.
my VY one tonner has a 2100kg towbar from factory and doesnt run a external cooler at all. When i was at the wreckers the other day no VY's that had factory towbars has any external coolers either
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
The later models seem to have dual pass coolers. My VX does. Trans goes in one side out the other. Then there is a hard line tying the bottom together.
