frankfava
- May 24, 2012
- 12
- 0
- 1
- Location
- Sydney
- 1994 VR Commodore S
Hi all,
For a while now, my V6 VR has been running rough and shaking the engine in low revs, sounding and running like the timing is off. Code 56 "Lean under Load" keeps on being logged too.
Whilst driving, a loud noise came from the engine and chunks of rubber were coming off the crank pulley. Now the shaking is worse.
Are these things related. If the crankshaft pulley was already starting to go, does that explain why it's been rough, timing has been off and the code is being logged?
I found this thread and it helped me alot. I know I can drive it now, but still need it fixed.
http://forums.justcommodores.com.au...e-1993-1997/190281-v6-crank-shaft-pulley.html
Where can I get a 3 Jaw puller that fits into the holes or a proper balancer puller? Do I need a new crank pulley but can use the same balancer (as long as I don't wreck it)?
Hope you can help thanks Frank
