waikato willy
- Apr 28, 2020
- 68
- 106
- 33
- Age
- 45
- Location
- New Zealand
- 1984 VK calais
ill get some pics tonight(need to pull my ruined W55 gearbox)
with the viscous hub the rpm is factored with air speed, the faster the air speed the faster the cool down the less engagement or speed the fan will produce, so on the spot revving its ass off will heat the viscous hub up alot making the ports open letting the silicon oil through creating more drag making the fan spin faster, so on the road cruising around the fan pretty much does stuff all till you stop and sit in traffic and the radiator heats up, you can manipulate the amount of drag/spin with thicker hub oil, and RC car hobby shop sells this stuff, I put 10,000cst into the hub on my landcruiser to make the fan engage harder and spin faster for towing(factory silicon oil is 5,000cst)
this is the hub I bought
https://www.onlineautoparts.com.au/...-Engine-1988-1999-incl-Safari-FCF37/ZPN-13093
I had to make a small spigot to centre it to the water pump and i needed some 5/16 unf studs and nuts to bolt it up
also this needs to be redrilled to the right pattern
I already had the plastic fan from a wreck and it bolted to the hub
the amount of air these things move is awesome, kicks ass over a thermo fan by far, even without a shroud it still worked better than the electric fan I had mounted
