Ve diff bolts stuck
HDJ
2016 SSV REDLINE
so I’ve got a 2012 ve sedan and the diff drain and fill up plug won’t come off. I’ve tried as hard as I can with my 8mm Allen key but for some reason they wont budge I’ve tried using my breaker bar other end but still no luck.
Any help would be appreciated.
HDJ
2016 SSV REDLINE
Are you using a hex key socket? Shouldn't be that tight.
Worst case try some heat first.
I assume so I mean I picked up the 4.58 25 Allen key set craft right from Bunnings which has an 8mm hex Allen key. I’ve used a hammer and everything but no luck. Though car has been siting in the garage for a week not sure if that’s the issue of being too cold
HDJ
2016 SSV REDLINE
No I’ve got a hex Allen key 8mm
HDJ
2016 SSV REDLINE
With a short head
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
krusing
Melbourne, Bayside
Tap it with a hammer, Brass or Copper Hammer, not a STEEL hammer.
I said Tap it, not BASH it ! :D and it should shock it, to be able to loosen it.
Yes, a Hex set should do it [decent set] with a breaker bar, and make sure it the correct size,
because if you use an under size hex drive, and you round it out, you can guess the result, :eek:
you will end up kicking yourself for not using the correct size. :mad:
07GTS
Australia
VEGTS BUILT BLOWN E85
if its super tight it will cost a little more but get a good impact allen key socket so its stronger and wont distort as easily as the non impact
