Ve esc/abs fault
Vespers86
37
Frankston
2008 ve commodore omega
Hey everyone, I’ve just had a electronic stability control off/ abs fault light come up on the dash of my 08 VE Omega, apparently it’s a common fault with the ve series 1, does anyone know what’s most likely the cause of it?
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Check the wiring harness to the rear wheel speed sensors.
FXST01
The Grey Man
Perth, WA
VP V6 Exec
Post your problems in the VE section, not the VN/VP section. Probably get more help there.
Vespers86
37
Frankston
Sorry everyone, just realised I posted ve commodore thread in vn commodore section by mistake, I’m not sure how to delete post
lmoengnr
Donating Member
Sunbury Vic.
Contact the moderators.
Immortality
Staff member
Sth Auck, NZ
Thread moved.
Fu Manchu
WA.
Check abs connections on the hubs.
A low battery charge will also set this fault. It can be caused by an old battery not holding charge, an alternator that might be faulty or the charging system not doing its job.
There is a software update that Holden can do that can rectify this.
DAJOKER
Adelaide, SA
VE SV6 II Wagon
I had that, only once though.
Was a dirty MAF sensor.
Pulled it out, bit of contact cleaner - done
h8tensv6
Newcastle NSW
2009 SV6 2002 VX 1989 VN 5 Litre
Get the codes scanned and will pin point the problem. Could be any number of things as said above. Wife's omega did the same. Got it scanned and found the rear wheel abs sensor was at fault. Changed that and all good. I know supercheap will scan the codes for you if you don't have your own.
Vespers86
37
Frankston
thanks everyone for the replies, I like to fix/service everything I can on my car, saves labour costs and I know the jobs been done properly
