I have a daily 06 SSV that I blast around the track, then drive home. Then to work the next day.
I found the following to be weak areas of the standard commo that you should start with first.
Brakes - Minimum HSV 4 Pot all round, if you can get a cheap 2nd hand set. But really, do it once, do it properly, go Alcon or AP racing 6 pot front 4 pot rear. I have the Harrop 4 piston monster kit = toasted brakes at Mallala. Lasted 12 Laps.
Power steering - The reservoir I found isn't actually water tight - opened the bonnet after a session to find power steering fluid everywhere. So get an aftermarket power steering reservoir and cooler.
Gearbox - My gearbox (6/manual) no longer goes into 2nd properly, unless its perfectly aligned. And sometimes not even then. I don't know If I simply have a bad example, or if this always happens after racing, but its never been the same since the first track day. So I'm going to wait until it dies, then get a HSV box and cooler.
Power - I have 315Rwkw, and revved the car to 6400rpm every gear change. Trust me, that is enough power to start with. If you want to supercharge later go for your life. So get a cam to begin with, but not ridiculously big so you cant drive it on the street.
Wheels - Don't race on 20's with street tyres like I started with. Get a set of racing wheels with good tyres then change them at the track. You're in a ute, so you wont have to put wheels on the back seat like me.
I would start there, then add more upgrades later. Next would be suspension as previously outlined.
Good luck, have fun.
