doopah
- Oct 6, 2011
- 4
- 0
- 1
- Location
- perth
- VT Clubsport 5.0
This is what i have installed in my series 1 VE SS ute
Alpine Electronics of Australia Alpine MRX-V60 amp 5 channel amp 50 x 4 @ 4 ohms + 200w @ 4 ohms for sub
Alpine SPS-610c components to replace the front door speakers and tweets
Alpine SPS-600 two ways
Alpine SWR-T10 shallow mount sub in sealed box.
Boss Audio 1 farad capacitor
Stock head unit
Only L & R outputs no front and rear (UTE)
All speakers wired with 12g wiring. 8 gauge to sub
Power and Earths all 4 gauge.
THE PROBLEM
It all works fine when the Volume is low, as soon as you turn it up the sound just stops. to make it work again you simply turn off the head unit and turn it back on. due to the remote sensing function on the amp high level inputs i would say doing this is resetting both the amp and the headunit. I have tried hooking up a remote turn on to the amp off an acc feed, when this was connected the amp didn't reset when the head unit was turned off and on. This points the finger at a brand new out of the box amp.
I just cant seem to work out the issue.
How can i test if the head unit is providing enough power??
All the gain settings on the amp are set to their minimum positions. Before the rear speakers were hooked up I did get it to pump a couple of times while playing with the Amp settings, as soon as the rear speakers were hooked up i cant even get the volume to go a third of the way without it cutting out.
If the Amp has High level inputs will using a line out converter or having the ASR RCA conversion done solve this?
Any help or ideas are appreciated
Stock head unit
THE PROBLEM
