Scorpion_Shooter
I would just check with your state laws man cause you dont want a pig to pull you over and give you a defect notice.
It's not legal in any state. Even when using projectors they MUST have auto-leveling and washers. I'm not saying don't do it, but you can't tell people it's legal when it's not.Well in queensland the HID xenon ballast kits are illegal in the reflector lens headlights. That's why i upgraded the headlight unit to projector lens cause of the cut off point which it produces making them legal. I would check with your state laws before doing any modification to anything.
D2R is a type of bulb that has a coating to block glare when used in the reflector it was designed for. These bulbs only fit in D2R sockets so you can't fit them into a VE headlight.Their are some cars that came out with HID and reflector headlamps... Thos HID's are called "D2R" look them up so im sure when adjusted correctly the chances of defect are minimal
D2R is a type of bulb that has a coating to block glare when used in the projector it was designed for. These bulbs only fit in D2R sockets so you can't fit them into a VE headlight.
