Simon[SSV-G8]
Simon[SSV-G8]
- Apr 22, 2014
- 7
- 0
- 0
- Location
- Melbourne
- VE SSV MY10 Special Edition G8 Utility
Hi everyone.
Need some advise
I've Got a problem at present with the VE, Been searching through a variety of threads for info with limited luck, and hoping someone has seen something similar to help.
The car is a 2010 Holden VE SSV Ute.
Not long ago the car indicated it was due for its 90K service. No big deal, just a service reminder after all.
Not long after that, the drivers door actuator started playing up occasionally where the stereo wouldn't turn off when the door was opened. Again should be no big deal, I'll get a new one from Holden during the service above.
However:
Last Last night the car clicked a few Km over 90,003k - just as I was pulling up to park. I Put it in reverse and immediately the check engine warning light came on, and has stayed on since.
Since it was late and i had to get home again, I was later forced to drive about 50km with it on.
During that time, Not 1 odd sound has been heard, no smoke, no odd fumes or smells, no vibrations, no overheating, voltage and pressures are fine, no fluid leaks or issues - Nothing whatsoever to suggest the car has a mechanical issue.
I Drive it again this morning, and again apart from the service light and the door actuator, I can not pick any possible problem for the check engine warning light.
Since I cant get it to a garage until after the weekend, I was hoping someone has seen similar to this before.
Could the warning light be because of the door actuator or the service requirement?
Could the warning light be due to a sensor or part which will NOT have any negative bearing on the cars performance, and leave it safe for me to to drive over the weekend?
Need some advise
However:
