Lex
- Sep 19, 2012
- 5,886
- 5,252
- 113
- Location
- Geelong Victoria
- VT Executive S1 V6 6 speed Auto Wagon
It says the hole is 14 mm.
Where are you getting 12 mm from?
Have you measured them?i ordered new VF brembo VF front bolts. They are too big. Unless the bolts are not correct.
I think the bolts are ok but the caliper was not labeled right on their site.Have you measured them?
If bigger than 14 mm email the suppler & send them back.
But get them to measure the replacement bolts first.
Make sure they are correct size.
Bolts may have been packaged wrong?
Have measured the calipher holes?I think the bolts are ok but the caliper was not labeled right on their site.
I'd be emailing the supplier.caliper was not labeled right on their site
Would performance workshops do this?You have to drill them out. Standard VE SS was 12mm. Brembo 14mm. I suppose you could get the correct part from a Brembo fitted car if it bothers you that much.
Mine was done by an engineering shop. I don't know about a performance workshop, you would have to ask them.Would performance workshops do this?
