Castrol Transmax Dexron VI two products in market had me confused
Need to purchase few more litre of the Castrol Transmax Dexron VI ATF
Noticed there were 2 types to use for VE/VF V6 & V8 trans (5L40E and 6L80E)
Couldn't get much sense out of 2 retail outlet stores as they had not noticed any changes in packaging
Firstly done what all good inquistive people do, read technical data sheet, could NOT see any difference
So decided to send message to Castrol Australia and ask the question, whats the difference, .....48min latter a reply came back...in my book that bloody good going for response time
Which brings me to the question
Going off Castrol recommended oil website it list 2 ATF oils for the Holden VF V8 6L80E trans fluid:
- Castrol Transmax DEXRON®-VI MERCON® LV.... which is what I used on 5L40E, ( purchased extra to use for the 6L80E filter/ATF change)
- Transmax ATF DEXRON®-VI MERCON® LV Multivehicle
Therefore want to know whether these 2 ATF fluids are identical, and can be used together in same transmission before proceeding with the ATF change
Thanks for your email.
Transmax DEXRON®-VI MERCON® LV is an obsolete product, it became obsolete and was
replaced by Transmax ATF DEXRON®-VI MERCON® LV Multivehicle.
The change took place roughly last March/April so it explains why the store had stock of both, it seems they still have old stock.
As far as those
2 oils are concerned the formulation is the same, both are the same type of oil ,Castrol changed the name of the product only, not the formulation.
As the product name was changed , marketing issued new labels which explains why the packing looks different.
Hope this helps
Let me know if you have any more questions.
Pic attached
OLD (LH side pic)
NEW (RH side pic)
