I have to admit I had some doubts with his post when he said he was ‘a bit of a camming expert and connoisseur’ as I’d read his post from back in March this year where he was recommending stage 1, 2 & 3 cams which is strange language for an expert as they usually talk in duration, lift, RPM and so on to back up their reasoning for their suggested cam size.
Still that’s no need to rubbish the AU, it may be an acquired taste for some in the looks department but it was a good solid car and I would be happy to have one of the performance versions sitting in my shed.
As far as your rough idle problem is concerned I think you’ve already been given some good pieces of advice from other members, swap out the fuel for some fresh stuff from another servo and if you still have a problem, have the injectors checked.
Your car is producing very good power at 440hp (328kW) at the wheels for a mild cam and bolt ons on a 6.0 litre, maybe the tune has been wrung out too far and needs to be backed off a little to make up for fluctuations in fuel quality.
