ajvx01
- Dec 13, 2010
- 911
- 6
- 18
- Location
- North east Adelaide
- 308 vc
Numbers aside id bet it is an animal and yea i would have thought a twin 2.5 would have been in order?
It definitely is, im just waiting on some backpay from work and then it will be going in.Numbers aside id bet it is an animal and yea i would have thought a twin 2.5 would have been in order?
If it is easier (and cheaper, incase more rates bills are due soon) as well as the fact that all the hangers are in place, twin2.5 into single 3.5" is another option.
It will also have less weight to it.
Really good numbers on the Dyno though. It will be good to see where it gets once full potential has been realised.
It was factory twin so all hangers are there and intact.
Ive been recommended/advised to run this
Twin 3" with an X pipe, mufflers, to the diff and then twin 2.5 over the diff then with another muff/ressi....and all to be flanged as a 3 piece exhaust (headers, Mid section, Tail section).
It sounds like a bizarre setup but it has been dyno and strip tested on a VK 355....
I would've thought a twin 2.5 would've been enough
yeah its funny...I get mixed info from exhaust shops, engine builders, tuners, mates, forums.....kinda does my head in haha...Twin 2.5" should be good to support up to 460 flywheel Horses.
Twin 3" definitely would not hold you back if you live in the 6-7k rpm range though.
Wot size headers u running and wot length collectors,
cant remember ur combo ill have to go back thru or thread,
I run 1 3/4 pacemaker step into 2 1/4 secondaries into 3inch collectors then x pipe twin 3 inch exhaust straight thru ran under diff for better flow out back into twin hooker muflers.
Same headers as you with the 2 1/4 secs then into 2.5....this was adequate for the bog stock 304 lol.Wot size headers u running and wot length collectors,
