Just made a quick diagram. Attached it.
Few things tho. The green and blue wires on the grey VN plug are the water temp sender (green) and oil psi sender (blue) wires. The water temp should be ok (I haven't hooked these 2 up yet), but the EFI 304 uses a different oil sender so not sure if it will work with the VK gauge.
On the VK engine harness connector (the one near the firewall next to the brake booster), the pink and yellow need to be joined coz the pink only has 12v during the 'on' position, and the yellow has 12v during the 'start' position. There's 2 pink wires tho, one thicker then the other. Ya use the thinner one, which matches the rest of the wires.
The ignition source for wire on the white plug I didn't join to the same ignition source as wat switches the EFI relay, only coz the EFI relay ignition source is in the engine bay, and the white plug on the VN loom is under the dash next to the ECU. I just started stabbing all the pink wires (using a test light) in the main VK loom behind the dash until I found one which had 12v during 'on' and 'start', then spliced into it.
On the fuel pump relay, I fused both the 12v source, and the output. Prolly didn't really need to tho.
I chopped out all the plugs in the VN which the loom connected to, and left a few inches of each wire on the plugs (to identify them, and to solder the new wires to). That way I make my loom using those plugs, and the VN loom will plug straight in. I done the same thing with the VK engine harness connector, as the engine harness for the 202 was no longer required, so snipped the plug and wired that into my loom so it would plug straight into the VK loom.
The plugs contain more wires for other things as well, but this diagram is just wat I've used so far to get it running and drivable. I haven't hooked up the wire to switch the thermo fans, or the torque converter lockup, neatral safety switch or even the speed sensor (will do the speed sensor soon tho), plus some other things.
