wow what can I say but the fricken dreaded misfire of the vn ..
I have replaced coilpack/dfi , spark plugs , leads , cleaned throttle body , new fuel filter and nulon injector cleaner etc ...
it helped alot replacing all those items ...
coil pack died couple months later ... was 2nd hand <----
bought a BRAND NEW coilpack/dfi and miss is slightly there ... put bottle injector cleaner again but at full bottle to 1/4 tank premium and go on the freeway at high revs/speed ..
all good now .... if you still have a miss then it's inlet manifold leak or ya injectors are really stuffed or the computer has dry solder joints.. or worse head gaskets gone .....
try replacing or reconditioning injectors first then if miss still there inlet manifold ... and thenif still there headgasket ... <-- if you have done a headgasket then just get a 2nd hanf engine be cheaper ...unless your engines worked and you want to keep it.
