VN Themostat
cameron20020
around revesby
VN Calais 1990 V6 3.8L
does it go below after the engines warmed up?
the thermostat regulates the temperature, if the temperature never goes up when you have plenty of air passing through the radiator, then its stuck open,
if the temperature goes too high, even with lots of air through the radiator, then your thermostat MAY be stuck shut, or you might have other issues
sitting at 1/4 is normal, for mine atleast
Morton
For external use only
33
Fairstar the Funship
Have you ever changed the thermostat? My car came with a 72 degree thermostat with two holes drilled through it :p
levymetal
TURN MY HEADPHONES UP
Somerville, Victoria
levymetal.net
HSV ENHANCED VP CALAIS
get a new one. they're not expensive. and if you can find a wreckers that actually has a 5ltr in the yard, tell me where it is! all the ones i know of sell the cars as a whole because there is always demand for conversions etc.
