[General] VN-VS & HQ-HZ V8 Ultimate Thermo Fan Conversion Guide (AU/Mondeo/BF/FG) PLUS 120a ALTERNATOR UPGRADE
EYY
VS Statesman
Ford twin fans - Wiring and Fitment --> Post #1
Alternator Upgrade --> Post #2
BF/FG Single fan --> Post #2
HQ-HZ BF/FG conversion --> Post 63, P4.
Why fit thermo’s?
Lately I've found that my car isn't staying as cool as I'd like it to in warmer (30+ degree weather) when the aircon's on and sitting in traffic. The old clutch fan works extremely well, but at idle, it's just not pulling enough air through. Without the air-con going it’ll happily sit on 82 degrees all day in almost any scenario. It's certainly not a necessity, but I feel that it'll prove to be an improvement over the factory setup for stop-start driving.
I've decided to fit thermo fans off a 1998 Ford Mondeo. Fans themselves are slightly smaller than EL/AU fans but some have suggested that they still do the job. Apparently the motors are slightly less powerful too. I investigated the EL fans, and actually have a set here - and while they would work, the fans interfere with the trans cooler fittings in the radiator, and the shroud was too big to fit nicely in between the charcoal canister on the driver’s side and the air con lines on the passenger side without some butchery. Apparently the AU's fit, but there are still a few 'modifications' required before they fit properly.
Things you'll need:
-Fans (Mondeo/au/EL depending on your application)
-Wire – From what I can gather, the minimum size you want to run to each fan is 30a. The main earth and power wires I used are quite large, I’m not sure of the rating but they’re a little smaller than 8 gauge.
-Fuses – you’ll need one fuse for each fan – fuses need to be matched to the amperage rating of the wire. I’m using twin 25a fuses.
-Relays - one standard on/off relay and two changeover relays - at least 30a rating. (if you just want on/off you can use two standard on/off relays)
-Fan switch (TFS108 in this case)
Mounting the fans
The Mondeo's almost fit perfectly without any trimming as you can see below - and they even bolt straight to my radiator after I’ve drilled a few holes (just need to make one small bracket for one the corner near the filler neck). I used a holesaw and an angle grinder to shape the shroud to clear the trans cooler fittings and radiator inlet/outlet nicely too. There's a bit of uncovered radiator below the fans unfortunately which should be covered to properly direct airflow.
Unmodified:
Trimmed:
Keep in mind that you’ll need to replace the water pump bolts with shorter ones if you're removing the clutch fan too. I’ll update with pics once I have them mounted and running. Some high density foam between the shroud and the radiator at the top and bottom is a good idea to ensure that the fans are sucking air through the radiator, and not through the gaps (air will take the path of least resistance).
Triggering the High and Low speeds
Here you can decide on whether or not you actually want to utilise the two speeds or not. VN-VS V8’s have the capability to trigger a thermo fan from the factory. In most of the older ECU’s the tune has the trigger set to turn the condenser fan on at 106 degrees OR when the A/C is running. This is much too high to use as a trigger for thermo’s. The easiest way to get around this problem is to have the tune altered to bring the thermos on at 95 degrees and off at 90 or so (depending on your thermostat temp).
In my case, I was lucky enough to find that the VS S3 sequential ECU with cpnd tune already has the temperature set suitably from the factory. Mine turns on at 95 degrees and off at 90 (using a 82 degree thermostat) which is perfect.
Unfortunately the factory ECU only has the capability to control the cut in/out temps of one speed. So I overcame this problem by fitting another thermo fan switch in the manifold. And because the factory ECU fan output is triggered by both A/C and coolant temperature, I decided to use this as the low speed trigger. For the high speed trigger I used the Tridon TFS108 (on at 100, off at 95). Tridon have some good alternatives for different temperature ranges and also alternatives for switches that can provide both high and low signals; although those ones tend to be a little more on the expensive side.
VN-VS 5L manifolds have an unused boss that can be drilled and tapped for the additional fan switch. I found it easy to do when the manifold was still on the car with the radiator removed (apologies for the poor lighting).
Wiring
The reason I chose the twin thermos is because they're easy to wire for two speed operation. For low speed the fans are connected in series. For high speed, the fans are connected in parallel. This is accomplished by using three relays (one standard and two changeover relays) as you can see in the diagram below. Credit to the original poster of the image.
IF you decide to use the fans on high speed only with only one trigger, wire sizing and fuse ratings are especially important. On start-up these things draw an incredible amount of current. I’ve read cases where people have tried using circuit breakers instead of fuses to avoid replacing fuses. Using wiring and fuses of the correct rating should avoid any problems like this.
*Disregard the extra relay on the end, it’s for a set of driving lights.
I though it'd be worth doing a writeup on the twin fans being fitted to work with aircon, the factory trans cooler and with high/low fan speeds, so hopefully it's able to help someone. I just need to find a couple of hours to finish fitting the fans and i'll update the thread with more pictures and info.
Feel free to add any info or make any suggestions!
EYY
VS Statesman
Alternator Upgrade
There are only two changes that need to made to the VT alternator to make it work. (VT alternator required for the twin fans - 85a alternator does not produce enough current at low rpm - upgrade recommended but not 100% necessary for single bf/fg fan)
1) The pulley needs to be changed
2) Cut off the support bracket on the rear housing
1) The Pulley
This part was the most difficult as I wasn't sure exactly what I needed. I found the original Bosch part number, but it's no longer available - I spent a long time calling different parts stores and even bosch themselves, which meant I needed to find an alternative. The difficult part is that the alternator shaft is very short compared to most others. This means that you need to use a cupped pulley so that you have enough thread to bolt the pulley on.
I spent a bit of time looking online and couldn't find anything that would work straight away, but since I have access to a lathe I purchased one of these:
http://www.ebay.com.au/itm/TUFF-STU...779439?hash=item1c4ec777af:g:hgEAAOSwrklU7nDR
It's a double row pulley that bolts on in a similar way to the factory pulley. Be careful if you buy one, some share the same part number (TUF7610F) but have different diameters. I purchased the 2.625" pulley as it's the same diameter as the GM unit.
This pulley slid on perfectly and the rear V section happened to sit in exactly the right spot. The only problem was that the shaft was still too short to tighten the nut. I needed to machine 8mm from the centre to leave enough thread to fasten the pulley.
Cutting off the second V:
Machined the inside of the pulley and tidied up the outside a bit and bolted the pulley on:
That's the hard bit, which doesn't actually end up being hard once you figure it out.
2) Rear housing support bracket
The bracket that needs to be removed is just below where the regulator would sit in this pic:
I wrapped the alternator with a damp rag before cutting the bracket off with an angle grinder. I wasn't too particular about it, I just needed to get it done before I found myself stranded again.
Reinstall the regulator and you're good to go!
Fitting the alternator
It bolts up exactly the same as the old one. I noticed some mentioned clearance issues, but in my car clearance isn't a problem - even with an old (stretched) belt. The alternator isn't limited in adjustment at all. I suspect this may be a problem in earlier commodores and other conversions though.
Belt tightened and all back together (excuse the messy bay, I still need to do some tidying and hide some more wires etc.) :p
So the VT alternator is on and working extremely well - with thermo's, A/C, radio, wipers on high and headlights on high beam it doesn't drop below 13V at idle.
BF/FG Single Fan Upgrade
This setup will be using a single speed, although the big single fan can be setup for two speeds if you desire. The BF fan is noticeably quieter than the twin fans - but I haven't fitted the single yet, just observed during some testing.
I've purchased a second hand genuine fan and have chosen to run my own relay/fuses for this setup.
Again, here's a list of wiring components purchased:
1) 85a rated twin core wire (only 1m or so req)
2) 9.5mm Heavy duty 80a relay base (purchased online for approx $15 for a pack of 5)
3) 9.5mm Heavy duty 60a relay (from Jaycar $9)
3) Solder, tape and heatshrink
4) Fuseblock from another commodore - twin 30a fuses required (25a fuses aren't quite enough).
The wiring is very simple, positive goes from battery and is split to two fuses>Relay>Fan.
The negative for relay trigger and fan are attached to the body of the car just above the battery, and the positive side of the relay trigger is connected to the thermo fan output from the pcm.
Black wire is negative.
Pink wire is positive (high speed).
Middle wire is for the low speed and goes through the heat sensitive resistor (thermistor) which on the front of the fan housing - this is where you connect 12v for your low speed fan if desired.
Thermistor:
Crimping the connectors for the relay base - the right tools are a great investment. This one's from Jaycar and was under $20. I always solder them too.
When joining wires I find that wrapping a few strands of heavier gauge wire around the join helps to keep things neat when soldering. It also helps to slide your heatshrink on easily and ensures it doesn't catch.
Fuses:
I just need to fit some terminals for the battery positive and the earth, and it'll be ready to install. The fuses will be located in the fuse panel in a vacant slot, and the relay will be located just next to the fusible link box/rail.
When it comes to fitting the fan, some trimming is required around the inlet/outlet of the radiator and the trans cooler fittings. The thermister needs to be removed (I just cut the ceramic coated coil off) and repositioned the plug so that it wouldn't interfere with the upper radiator hose.
The factory ford mounting points also need to be cut off.
This pic shows all necessary modifications and bolted to the radiator using the vacant mounting points on the plastic VS radiators using speednuts from supercheap.
Fitted to the car and working as it should.
This setup is a lot quieter than the mondeo's, and the BF fan is noticeably more effective. At approx 20 degrees C ambient temp, the BF fan pulls the temp from 92 down to 88 or so in only 22 seconds which is more than twice as fast as the previous setup.
At the risk of speaking too soon, I'd almost go as far as saying that I wouldn't bother with alternatives after trying this setup. Bring on summer :p
gtrboyy
vt ss & lc gtr
I'd have cheated using vs v6 thermofan setup that bolts straight up or single BF for crazy flow,
<<< After au fans/vs v8 series 3 radiator conversion in baby lc gtr was a headf*#k to do.
Current car(vh sle) have stuck with clutchfan/shroud..it works well + engine bay still messy...might do mondeo fans if find cheapies 'cos tiebar clearance.
Read somewhere can get some relay or diode on a timer to fire up 2nd fan.
Nice write up dude....even with pics of the fraud up there ;)
EYY
VS Statesman
Yeah, I was actually looking for a BF/FG thermo but they were already gone - that's when I came across the mondeo's :p
Thanks mate, that's something else I wanted to add; IF you decide to skip the two speed setup and just have them running flat-out it's a great idea to use a time delay relay (just to delay the trigger to the second fan relay) if wired in parallel.
Those thermos draw a MASSIVE amount of current on startup. The two speed setup negates the need for this as when the high speed is triggered the fans are already spinning at half speed so the initial current draw on the switch to high speed is less and for a shorter period of time. It's certainly important to factor in the capability of the electrical system (main wiring and alternator especially). Once they're spinning they don't draw much current at all (so I've read - I haven't tested this myself).
Cheers!
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
Nice write up. BF/FG big single is a better option though. Can be found on eBay for bugger all and your getting a new fan rather then an old one with unknown life. Little bit of trimming but much better flow and a lot less current draw. Also means being able to just use the AC fan wiring with the temperatures changed in the tune. Saves having a rats nest of wires with lots of failure points. Never needed low and high speed was never that loud and never had any overheating issues.
Immortality
Staff member
Sth Auck, NZ
Good write up, maybe it should be moved to the How-to section or made a sticky in this section?
I too prefer a large single fan but the Mondeo fans do fit well.
EYY
VS Statesman
So I've had the fans on since Friday and they've been working fine (triggering as they should etc), but I'm having cooling issues - just as I was with the clutch fan. On a 28-30 degree day it can't pull the temp down with the air-con going (but will maintain it, even in traffic), and without the aircon going the temperature takes a fair while to drop. It also warms up even at 80k's and the temp takes ages to drop - at least 5 minutes driving at 100kmph.
Since it was having cooling issues before the new fan setup was installed, I figured the problem had to be elsewhere in the cooling system. I took the car to a radiator specialist (friend of a family member) and he was able to tell me straight away that the radiator is blocked. Feeling each corner of the radiator, the blockage is obvious. The corner near the filler neck was almost too hot to touch, and the corner diagonally opposite was barely even warm. I'll be getting the radiator cleaned out and the tanks replaced if it needs them this weekend, so will hopefully be able to report back with good results!
gtrboyy
vt ss & lc gtr
Thought it'd be easier just buy another natrad vs s3 radiator
Had one somehow got damaged apparently metal was so fine most places didn't want the job let alone warranty so bought new one elsewhere trade price
EYY
VS Statesman
I was very close to ordering a new one, but he assured me that my radiator will be good once he works his magic on it. And for less than $80 I thought it'd be worth having it pulled apart and cleaned. I was looking at one of the full alloy ones at around $330 for a decent one, but was told that it's overkill for what I'm doing here, so fingers crossed it works.
gtrboyy
vt ss & lc gtr
If can do it for $80 & warrant the work give it a go.
Ironically when had vt 5l cracked an end tank by air con guy then later on modded vy ss ute would crack end tank every 2-3 years wished had gone full alloy for ute.
vn-vs radiators dont seem to as bad on end tanks like wider cars...think might v6 radiator/vs thermofan next car..cheap as chips & light lol
