Adrian's Vr
22
Vr commodore manual
So wikki says a stock vr v6 makes 130kw so i removed the restrictor in the plenum, added a cold air intake (with K&N) and sports 2.5" exhaust and it manual, adding vy injectors too. So because the forums is a good place does anyone know a rough estimate that it may make now? Maily how much kw is added by removing the restrictor
losh1971
North Tas
VE Series I SS Ute
Removing the bell mouth will do SFA. I left mine in because its a Muppet Mod.
the_boozer
no more VK
51
Shitsville Morwell
hilux
has it lost any low down torque ? Go and find a piece of road you can 0-100 or quart mile time it. Time it now any after every mod you make to know if it gets you any useable power
Immortality
Staff member
Sth Auck, NZ
The primary function of the bellmouth is to even out airflow distribution in the manifold. IIRC the best results were to be had by cutting away the top part but leaving the bottom bit in place so it can still function as intended.
losh1971
North Tas
VE Series I SS Ute
Where did you see that fitting VY injectors increases HP? Ive done a fair bit of research and that one never came up.
losh1971
North Tas
VE Series I SS Ute
i have read that but from a decent search it would seem that even chopping part of it away makes little to no difference. Id be keen to see what @delcowizzid has to say on this as he races the Buick engine. I looked at it and can not see it being restrictive on a mostly stock engine.
Immortality
Staff member
Sth Auck, NZ
I had a VN which was reasonably quick for been n/a, the VN's never had em....
Boost hides many evils of manifold design so I'm fairly sure he doesn't use it in the VB he tunes.
Immortality
Staff member
Sth Auck, NZ
I don't think so much it increases power but they are a later design injector so in theory better atomisation of the fuel. Having said that, if they are used it wouldn't hurt to have them cleaned first for optimum performance.
losh1971
North Tas
VE Series I SS Ute
If i plant the foot in the ute it gets up and goes reasonably well for a six cyl. I do have memcal and Pacies.
losh1971
North Tas
VE Series I SS Ute
so improved economy? Or bang for buck probably not worth it?
