Vr wont start after gasket change
YILDI2
www.myspace.com
FG XR6 TURBO /RIP VT II LS1 Clubby, VR Commodore S
i got my car towed from my mechanic didnt pay him a cent
because they couldnt get it started, they said it was the starter motor they changed it over for another one infront of me still didnt turn on just hear a loud noise not a clicking one and thats it doesnt start, before this they had somehow burnt the wires going from the battery to the starter motor
it would be great if anyone could point out roughly what i need to do to get it going again
thanks
OK UPDATE !!!!!!!!!!!!!!!!!!!!
the engine is seized !, the drive pulley cant be moved back or forth
what i dont understand is how the engine seized after they put the engine back together the car was running, then after they burnt wires engines sezied ? i dont get it, but after some checking out i think the starter motor wires got burnt coz it was touching the extractors, i found melted wire all on it no other way to explain the wires
but how does the engine seize later on after the car had been started and driven round the block
how c an i identify wat part is seized ?
patskies
34
townsville
VT SS LS1 (vz monaro themed)
get them to replace the wiring they damaged
patskies
34
townsville
im presuming it doesnt crank?
YILDI2
www.myspace.com
what gasket?
did it drive to the mechanics to begin with?
more info?
ye mate it was a fully working car with nothing wrong with it drove it to the mechanics was starting aswell after the mls cometic head gaskets were put in aswell, but after they got the wires in flames from the battery to the starter motor it doesnt crank i think is the right word thanks patskies
YILDI2
www.myspace.com
the damaged wiring is replaced and they also chucked in another starter motor from the wreckers still didnt start
thats when i decided i had enough and towed it home
patskies
34
townsville
run a dianostics test.
and check all fuses.
If you are handy with a multimeter check your voltages and the starter
YILDI2
www.myspace.com
i cant do the diagnostics test on mine for somereason
but ill deff do the rest
thanks mate
vk.jonno
south east
Vk commodore, hq one tonner, hj ute,
good on you for not paying them mate!
read ur other thread
VR_Acclaim
Banned
Vr acclaim
They may of destroyed more wiring then they think, check the wiring to ur engine fuse to
