shedevil666
Yeah mateHave you checked the fuel pump?
That's what I thought cheers man, gonna try that when I get home, let ya know how she goesOn the intake manifold. Usually very close or directly on the throttle body.
Will do this over the wkend, away for work atm cheers mateFault code check if delco ecu? Does it stay running if use throttle?
Would expect idle to change after it starts but that does nothing which is weird...give it a once over unplug & plug sensors etc might get fluke fix or find something.
If anything gilemers will run the battery and alternator dead before anything, it's literally got me stumped as to why it's doing what it is, honestly thinking of getting rid of it to get something differentGilmer drive setup probably make it under-charge but doubt that it will start up & conk out but slowly run battery flat.
