sproulee
- Mar 2, 2014
- 4
- 0
- 0
- Location
- Canberra
- Vs executive s1
Hi guys,
I have recently done an engine swap in my 95 vs executive. I wired everything up went to start it and all it did was crank. First thing I checked was spark. Second thing I checked was fuel. I noticed my fuel pump was not priming after letting it sit for about an hour before trying to start again, this time listening for the fuel pump. After I discovered the fuel pump wasn't working I immediately got the test light out. THIS is where it gets weird. Under the hood, I'm getting a great reading, test lights going nuts on everything to do with fuel pump. At the pump itself however the reading is THERE its just extremely faint. I changed the fuel pump anyway (thought it might have just been dodgy internals or something) but still have the same problem. After this i then proceeded to check all the wiring from the fuel pump to the relay under the bonnet and didn't find any problems with the wiring. Anyone have any suggestions on where to go from here or even better had this problem and fixed it?
Thanks in advance
Thanks in advance
