Timbo
- Jun 25, 2018
- 66
- 75
- 18
- Location
- Perth Western Australia
- Vs ute V8 manual & Vl walkinshaw
Thanks budNice ute mate
Thanks finally a bit of advice I can use . CheersRegarding your cam package. It really depends what you want to do with your Ute and what you have already done. It would
be a lot easier for you to give someone like Camtech a ring and let them help you with your choice. The bigger cams might
look more impressive on the dyno but might be a pig of a thing to drive.
Hey that's something to think about might just do the lot makes sense.. **** Box getrag tell me about it mine already has 4th gear synchro crunch around 2k to fix !!Yeah I've been looking into setups also as I have the exact same ute as you. I messaged camtech end of last year and got this back.
"If you are going to do a cam swap the cam below is what I would recommend.
You will have to shave the heads to get the comp up to 9.5:1.
You will get away with your 3.08 diff ratio wit this cam."
Camshaft CT2248 49907-110
Camshaft $770.00
Link bar lifters $595.00
Dual spring kit $462.00
Plus rockers will need to be done so another $600ish. Plus machining, gaskets and tune so expect over 4k if you do it yourself.
I haven't bothered doing it yet cause I don't want to machine heads for compression. Might as well do it properly and do pistons and deck. At that stage might as well even do a stroker as our blocks are already cleared for it. If you're willing to spend 4k you might as well spend another 4-6 and make it boss.
Everyone says do it once do it right so I'm spending my money on all the other bits that more power will break. Gives me more time to make the right decision and less work patching parts when a 400hp banger blows the shitbox getrag apart or your stock brakes fail to pull you up.
