VT Series 1 Driveshaft & rear sub into VY Series 2
Ralphski
Ralphski
58
Otaki, New Zealand
MY04 VYII 3.8 Executive - MY11 VEII 3.6 Calais VV6
Hey all,
I've just picked up a very low mileage (100K) VT Series 1 complete rear end (inc LSD diff & driveshaft)
It has ABS etc, same as my current VY Series 2 (with 500K on it)
My question for all you gearheads.... Can I put the VT rear & shaft into my VY?
From a visual eyeball it looks as though it will match up with my trans etc
Thanks to all
Immortality
Staff member
Sth Auck, NZ
Are you talking about putting the complete rear subframe from the VT into the VY?
I'm sure it can be done but it's a step backwards. The VY has improved rear suspension geometry as well as the extra toe rods which make the VY rear end better than the VT.
Ralphski
Ralphski
58
Otaki, New Zealand
Thank you,
Yes, I'm thinking about swapping the whole sub (can't just swap the diff & shaft, axels are different)
I'm not overly fussed about a step backwards in rear end handling, after over 500,000 it's just a bit of a hack nowadays
From what my eyes tell me, it looks like it'll fit, as long as the shaft spline matches the box...
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Thank you,
Looked at the differences between each diff & tailshafts?
Ralphski
Ralphski
58
Otaki, New Zealand
Put the right diff in it, there are plenty around.
If only it was that easy... Not only is the diff shot, but the hub bearings are whining worse than my ex, axle CV's are sloppy. With over 500 thousand K's it's all worn. To fix it all up, a bit at a time, it's going to cost a packet (I'm in NZ, everything is expensive... 91RON is over $3 per liter)
I got the VT S1 for free & it's only done 100K
Immortality
Staff member
Sth Auck, NZ
Well there is no reason it won't fit.
EYY
VS Statesman
I’ll be blunt, it IS that easy.
It’ll be cheaper and easier to do it properly the first time. Remember, there’s a reason Holden changed the design.
For something so common, I wouldn’t reinvent the wheel to take a backwards step.
Immortality
Staff member
Sth Auck, NZ
Go easy mate, if you see where he is getting **** isn't as easy as been in a big city and parts are not cheap if they are available and I couldn't easily get CV axles when I needed them in Auckland last year let alone everything else he will need.
The big down side of the VT rear end is increased tyre wear but mostly if lowered.
Ralphski
Ralphski
58
Otaki, New Zealand
Hehe.... That's one bonus in my favor... It isn't lowered (can't stand them)
I might just park it up, rip the rear out & see what I can swap/keep to make the best out of both...
S1 diff, S1 axels, S1 shaft in a S2 subframe.... who knows
Cheers for the advise though chaps, always appreciated :cool:
