Lex
- Sep 19, 2012
- 5,967
- 5,352
- 113
- Location
- Geelong Victoria
- VT Executive S1 V6 6 speed Auto Wagon
The new tps came with the spacer?It stayed in place when I changed the TPS.
that pretty much rules out ignition and fuel supply
check wiring to tps........ Checked, no damage found.
can you check fuel trims? What does that involve?
how old are O2 sensors?...... Never been changed.
have you disconnected battery and gone for a drive before it warms up fully.....When the problem first started it was only at normal running temperature, as of today the problem is there from a cold start.
Battery has been disconnected several time when fitting new parts.
you need a suitable scan tool adl are not normal obd2can you check fuel trims? What does that involve?
Maybe try this: put dash into the engineering mode (if it's a standard dash) or just look at the instantaneous fuel consumption readout if its a 3-window dash. Get the car to the poinjt where the jerking is happening (as you said coasting in 4th or 5th) and give it the slightest amount of throttle. Does the fuel consumption readout give a steady litres per hour (about 1.3) or litres per 100 k's (on the 3-window dash), or zero - ie no fuel being used?
