Tick Tock sounds more like a BIG CACTUS ROTATING Knocking of metal parts. Also you have a major exhaust manifold leak, a misfire and an air filter/inlet manifold issue and that’s before anyone knows what it actually drives like and what the noise/damage issue is.
It’s a major cost to fix noises coming from crank/bearings and camshaft/bearings/roller lifters. If you’re lucky it could just be a seized twisted roller/lifter or just a broken/worn cam lobe which would sound like your noise.
Firstly do a compression test just that you know about condition of piston and rings and check the oil pressure. With these 2 things in hand, if you decide to get engine fixed at least you know whether its worth getting it done or time to get another 2nd hand engine as the cost will probably be more than the car.
Lol, oil pressure is done from the oil sensor, cylinder testing only tells you if you have blow back from warn rings it wont diagnose a failed oil pump or blocked oil filter or proper pressure.Compression test helps determine oil pressure as well if done properly
