Ok cheers mate, so as long as it’s from an 04/05 model it should be sweet? as mines an 05As far as @OldSkoolGP has found, 04/05 should work and 06/07 should work depending on where yours falls. What differs is ute v sedan v etc.
As long as you also get the correct body type as well as I mentioned in the previous post. Not just the year.Ok cheers mate, so as long as it’s from an 04/05 model it should be sweet? as mines an 05
I have discovered new information about the VZ ABS modules. 2005 and Pre-February 2006 Pontiac GTOs came with a Bosch ABS module with software idenifier 0202. These modules can only be reprogrammed to select transmission despite other choices being available on the Tech2. Post-February 2006 GTOs came with an ABS module with software identifier 0203. These modules can be reprogrammed to select LS2, L76/L98, or LY7 engine so long as they are paired with the correct transmission. You also have to select a chassis that the engine/transmission combination and ABS module came in.As far as @OldSkoolGP has found, 04/05 should work and 06/07 should work depending on where yours falls. What differs is ute v sedan v etc.
This should just be a configuration edit, so should be able to make the edit! I don't have one on the bench right now to checkout, but will be moving towards VZ stuff soon since almost finished up with the VE/VFs.@TazzI I've been taking to a guy that has a VZ Calais ABS Control Module from a V6 model. He says they did make the VZ Calais with ESP and a Gen IV V8, but it is rare.
But since it does exist, does Envyous have the ability to install the later software Gen IV V8 on an ABS control module if necessary?
