shrapnel
cold_carve, i had some spare time today to replace front tweeters and front door woofers with jaycar's. Thanks for your info, all worked out great.cold_carve said:i mounted my tweeters to the bracket once i removed the oem tweeter and ran new cable from that to the crossover.
with the tweeter wired up and installed.... step back thru the steps given n u should be laughin.
please note with the top trim carefully to locate all 4 clips and firmly press into place
BUT, I'm at the point of wiring the crossovers to the stock h/unit. How do you get the *cradle* for the h/u out? (I got the h/u out, no dramas). I presume you've wired the crossover's input to the outputs of the Blaupunkt h/unit but as you know it docks into special connectors in the cradle, so you must have removed the cradle and did the wiring behind it. Correct?
