BoB_The_Ninja
- Jul 15, 2018
- 4
- 0
- 1
- Age
- 28
- Location
- Maryborough Qld
- 2005 VZ Crewman S 6Spd Man
Hey guys, I'm new here.
What happened:
I've been swearing my head off at my car for a couple months now. Originally the car had blown the ODD injector fuse (replaced fuse, and rebuilt injectors, replaced the injector harness).
In my excitement of "woo-hoo I can drive the car again" I have reversed the polarity getting jump started.
The problem:
My 10/2005 VZ s Crewman 6 speed manual, idles rough as guts and won't drive (I can Drive it but at a crawl...20km in a 100 zone kind of crawl..with my foot flat)
I turn the key, it'll start and run like a dream, however the throttle body clicks like crazy (the TB is NOT the problem as I have gone through 3 of them testing and cleaning etc so not all 3 would be duds) once the car gets warm (so it idles at just over 1000rpm until it's warm and then drops to about 650-700) it becomes the devil, it runs rough as hell and surges up and down. And when I push on the throttle even slightly the TB clicks away and the car runs even rougher, puts it's self into low performance and safety mode. Only sometimes when I push very easily and softly on the throttle can I rev it higher than 2k without it running rough(runs quite nicely actually) and then it will drop itself down to almost a stall.
I drove it to the wreckers to replace 02sensors and it was clunking in the rear end, with the dash starting to beep and show a brake error "((!))" but only gets half way through one beep and stops meanwhile my car.
O2 sensors unfortunately didn't fix the problem. I have had a lot tested an replaced since the beginning
Fuses and relays
Injectors
Throttle body
Battery
Fusible link and main alternator cable
Alternator
Plugs and coils
Upper intake gaskets
Fuel pump
Have had the ecu and bcm and pcm all tested and told they are fine
No tech2 or obd2 device is picking up any codes
What is going on? Any help is appreciated!
What happened:
The problem:
Fuses and relays
Injectors
Throttle body
Battery
Alternator
Plugs and coils
Fuel pump
