- Apr 15, 2006
- 22,634
- 20,526
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
Well Bathurst is over and today I worked on the WH Statesman 3.8L. today I replaced the MID Lim Gasket and I was very particular in fitting it as I checked everything. I also Checked whist I have the lid off the manifold I Checked the Purge Valve and its pipe to the throttle body and I sucked into it and found it closed and the hose stuck to my tongue so I have no vacuum leaks there.
STARTED THE CAR.
When I started the car the car does the Same thing. It went to 1200 RPM immediately and stayed there for a minute or so and I turned the car off and started it again after 2 minutes being off and this time it started normal at around 1000 RPM and slowly went to 850 or 900 RPM,,, GOOD but after a minute it went to 1200 RPM and stayed there for 2 minutes then 1100 RPM then 1200 RPM then it went to 1100 RPM than back to 850-900RPM. WTF??
WHAT IN THE F..K is going on.
I checked the Code ( Battery was disconnected for 3 hours whilst I did the LIM replacement) and the CODE was FLASH FLASH FLASH FLASH FLASH FLASH FLASH FLASH FLASH FLASH..... PAUSE ....than another FLASH FLASH FLASH FLASH FLASH FLASH FLASH FLASH FLASH FLASH..... PAUSE.... then FLASH, then PAUSE than FLASH FLASH. Now in my book that's 0012 which means the car is fine and running good,,,, BULLSHIT!!
After this I decided to remove 3 spark plug out ( two on one side and one on the other side ) and considering the plugs were replace by me around 1800 K ago around two mounts of driving I found them WHITE to a point (LEAN) that I could put them in the box and sell them as new again. Yes You had to look twice to see any marks on the Centre porcelain to see if they have any evidence of browning on them.
I checked Two on the drivers side, the back and middle cylinder and on the other side I checked the front on the Passengers side. remember No code was spat out to me.
I need more test tool to find this issue with this car but I dont want to by them as I have spent to much money on a car that is not mine.
I just about to give up on this statesman, I have spent more time on this compared to me Cheap VE fixing everything.
Reading plugs on an EFI engine is not like reading plugs on a carb engine. EFI has lean burn so the plugs stay clean when it's running well. Our old VS always had clean white plugs at 10K intervals.
The change in idle suggest either the PCM is getting a dodgy signal from a sensor/dodgy wiring or the PCM itself is stuffed.
