Or look at ZB parts list and consider if you can retrofit such parts into your VF![]()
a project that I have not managed to find time to finish is installing a wireless charging coil under the rubber insert below the ac controls.
its pretty simple to just use the guts out of a charging pad and connect it to a 12v>5v usb charger and hard wire it to the wires that go to the 12v acc socket.
doing it this way I can just put the coil below the rubber insert so everything looks factory but placing the phone there will allow it to charge.
I was thinking something like this but in black
cut into the rubber mat and then wired it the cigarette plug for accessories power.
Great solution but my phone is too big and thats too low for gps use.I use this which works great for me. I use a Samsung not sure if it'll work with Iphone.
https://www.banggood.com/Qi-Wireles...327.html?rmmds=search&ID=224&cur_warehouse=CN
