Wireless CarPlay / android auto
vy_berlina03
Liverpool NSW
MY15 SV6 Storm
Hi Guys,
I purchased a wireless Apple / android auto module for my VF yesterday as I wanted to keep the factory look and not retrofit or modify the existing wiring or my car in anyway.
It is a plug and play solution that allows you to retain all the factory features and all the steering wheel button work .
It uses the Bluetooth audio option I can’t find any issue with the audio for music playback or even phone calls.
It even displays the aircon information when using car play,.
The reverse camera automatically comes on when you select reverse, and the unit can be set to auto boot up when the car is turned on.
One thing I have found so far is there is no volume displayed when you increase or decrease the volume
The unit comes with a detailed instruction manual on how to install it and shows you were to place the module ( it getting placed in the passenger foot well under the carpet.
They accepted my offer for $700 then I used my eBay plus discount to get it for $572.50 with local pickup.
https://www.ebay.com.au/itm/3256526...n1VBnaiTme&var=&widget_ver=artemis&media=COPY
dassaur
VF Calais V V8 Wagon
Hi Guys,
Thanks for the write-up. ALways good to have options for our members!
Hopefully all who do this have the HVAC fix to avoid wet spots where the module goes!
stooge
wa
Turbo Alpaca
I wouldnt put it there lol.
It is supposed to go up behind the dash when you remove the mylink baseunit to install it.
Its just another variation of the mitm boxes sold by kayhan, importroad etc.
Its the bluetooth audio quality that will annoy most people with those boxes but being able to switch between the mitm box and factory unit is a bonus.
Z31na
2013 VF Commodore Evoke
Its the bluetooth audio quality that will annoy most people with those boxes…
Wireless carplay only uses bluetooth to make the initial connection then hands off to a direct wifi link so in theory quality shouldn’t be an issue.
stooge
wa
Turbo Alpaca
The bluetooth is used to send the audio to the mylink.
In the older vf s1 series they could use the aux connection but the s2 does not have that so the mitm boxes just use bluetooth to cover both variants.
This has nothing to do with carplay.
From the link the op posted
Item description from the seller
The aircom information will appear the apple carplay and android auto section when you use aircom. 9 The apple carplay and android sound through the factory bluetooth audio,no need to factory AUX or USB.
hsvluva
42
VF V8 Calais
Guy with great cred sells this for $599 in Perth, $350 more if u want it fitter. Better option for support I think
Super Coach
GTS, S, CV8Z, SSVR
GTS, S PAK, CV8Z, SSVR, CALAIS V, MSE
are there links etc as the where to buy these?
Anthony121
VF SSV Redline MY17 & VF Director
Do you keep the existing Mylink unit?
Forg
Regal Peackock VF SS-V Redline Wagoon
The ones being spoken about, yes.
The ones which replace MyLink tend to be somewhat more exxy (and less common - it's harder to produce the plastics/bezels/buttons/etc in a CCP factory than a hidden add-on box).
