Jon Rothwell
- Apr 12, 2015
- 5
- 0
- 1
- Location
- Beverley WA
- VS Statesman
OK, so here is where we are at. 190 Alloytec V6, At first cranking was intermittent, even when jumpering the starter relay, changed the starter motor and problem solved, put in a new battery just to be sure. Now it starts by jumping the starter motor relay with the ignition on, we just removed the relay case and manually trigger the relay. Now it will crank and start at first with the ignition on and manually triggering the relay, after that it will restart from the key even when the doors are locked and re-locked, and after the security light comes on. BUT, after about 10 minutes it will not start from the key again, and needs to have the relay triggered with the ignition on to start. It comes up with a heap of error codes, but even re-setting those makes no difference, after 10 minutes it will not re-start from the key and all the codes come back. We get ABS, CANBUS, FUEL LEVEL, ECU, SRS, ABS and Stability control failures. Engine runs great and other than this issue it is a great car to drive once you get it started and clear the codes.
Any suggestions please?
