No, you were saying driving style and I said driving style suited to car, not every condition the car will meet. Yes you can have an exhaust better suited to your car and driving style?! More torque near stock torque convertor stall speed versus mang.
Enough to know that's a simplistic explanation, and only one of several key forces affecting header design... of course I know how they work. The reason for exhaust gases "banking up" right back into the fricken intake is that too large an exhaust exit CSA doesn't work for stock CFM because the exit velocity is too slow.
Not noticeable at OP's stock engine exhaust CFM.
Yes, by its nature, but still flows adequately for stock engine's exhaust CFM.
Possibly, not because of removing restriction to his current weak CFM but because it promotes flow thereby increased velocity (within the parameters of stock tune). Definitely not up scaling from 1 1/4 to 1 7/8, that's backward.
Mate it's the headers which are suited to the stock tune! Putting on 1 7/8 is for a totally different state of tune!? Remove the torque ring at the flange (like I did) and see what happens.
Not quite like that with AFR feedback from the bungs, put the 1 7/8 on and see how a stock tune likes dem apples!!
Well yes, if it will even run untuned without limp mode, warning lights etc., and ECU compensates AFRs ideally for new bung placement then it may produce a smidge more with tits screaming... ie not the most practical improvement for the OP who is careful about cost, no scavenging gains nor torque gains in his stock CFM tune every day driving.
The main reason people change the stock system on ANY car is predominately performance gains. Some just do it for sound, but in my 25 years of doing this, the majority want more go. With this in mind, they generally drive the car harder to take advantage of the exhaust, or more to the point to extract the most out of the improvements made by the exhaust upgrade. (pun intended). So by this reasoning, bigger is generally better.
Header companies have spent a lot of time, money and thought into header design. With the exception of a few copies, they are made that way for a reason. There is a reason the primary pipes are a certain diameter and length, where the collector is and how it is designed, even the length of the collector. In an ideal world, you would order an exhaust system tailored to your engine and how you drive it, but that would be cost prohibitive. So header manufacturers make their products to cover a broad range of circumstances to give a better increase over a larger cross section of consumers. Yes, exhaust design for the general public is a commercially based decision. In short, what is available, works.
Without trying to sound like a smart arse, do you have evidence to back that up?
And this is the statement that hits the nail on the head. Adequately. Yes, the stock system does indeed flow "adequately", but we don't want adequate, we want optimum. Fitting a better header and free flowing exhaust will inherently increase performance because is flows better than "adequate". You WILL increase velocity, so you WILL increase performance.
Just doing some calculations, the best header primary pipe for a 6.0L is indeed 1 7/8". That is what will provide a torque boost at around the engines peak torque RPM. If you are talking tuning an exhaust to an engines peak torque, then 1 7/8" is pretty much bang on.
Because you are removing a restriction….
Then I will save for the CAI, Headers and Tune to get done at the same time and to get the most out of my car for the money.
I looking at if I go MAFLESS over a MAF tune?
There was a thread on here about exhaust myths.
The test car was a silver 6 speed 317 Senator. The tested every combo of exhaust and the 1 7/8 primary 4 into 1s with 3" 200cpi cats and 3" cat back made the most power before tuning.
They tested it with;
stock exhaust,
HSV front, 2 1/2 cat back
HSV headers, hi flow cats, 2 1/2 cat back
1 3/4 tri Ys hi flow cats 2 1/2 cat back
1 3/4 4 into 1s etc
And finally the 1 7/8 4 into 1s with cats n 3" back and it made the most power on a stock motor (no CAI, no tune)
The video was from a workshop called garage I think
I thought you implied that you will be doing a tune but wasn't 100% sure
