disconnect heater control rod next to where your left ankle would sit on drivers side , little white clip on swing arm
drop panel below steering column ,3 clips twist 90 degrees
3 screws down driver side of dash facia
drop glove box 1 clip in box at rear right , slide clip out towards passenger side
3 screws down passenger side of dash facia
remove ashtray
remove panel around shifter clipped in only and slide back
3 screws along bottom of center facia panel
unclip facia panel carefully
Unplug the LED for immobiliser (this sux)
4 screw hold dash facia and 1 in AC controls
2 plugs in rear of AC controls + 1 hose cluster
undo 2 Large chrome screws going straight down and console will drop
remove dash facia
2 screws holding deck in
Orange = constant 12V
yellow = accesories
Black = earth
Brown/white = illumination
yellow/red = elec aerial
dark green & light green = front right (DG-)
tan & grey = front left (G-)
dark/black & blue red = rear right (DB-)
brown/black & yellow/blue = rear left (YB-)
There is 3 screws holding the brackets to the deck , if you drill a new hole between the 2 screws that are towards the front of the bracket it will line up with most after market decks and will screw straight in and look stock again.
Need to drill on the white dots.
