/// KBAGZ' Impulse R8 Clubsport
Trayner
Fresh prince of Pakky, Gangsta
Gangsta Hundy
Those tail lights looks so much better then the stock ones , how much light do the reverse lights throw out at night ? Im after a brighter/whiter set for mine
K-BAGZ
De Plane! De Plane!
Far North QLD
VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
They are exactly what I wanted and more.
Heaps mate! Way better than the stock halogen bulbs. Mine are around 6500K, unsure of lumens. I'll go outside and take a few pics for you right now.
K-BAGZ
De Plane! De Plane!
Far North QLD
For you, Trayner. Mind you these are 45 LED SMD, Aerpro do have 24s as well in their catalogue. But they aren't as bright, as I have them in my SV6.
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
Damn they could do as headlights. Sucks to be any one behind you if you put it in reverse at night.
K-BAGZ
De Plane! De Plane!
Far North QLD
You have a point there wraith.. I'll set up a dummy test with another family member's car and take a photo from their drivers seat at a normal distance at night.
My dad has two high output underground LED work lights hardwired into reverse in his Patrol, and they are blinding.
Trayner
Gangsta Hundy
Wow man they are bright as , do you have a link to them at all ?
K-BAGZ
De Plane! De Plane!
Far North QLD
Yes I do, just for you.
BA15S45W Replacement bulb 15mm bayonet | Aerpro
I left all my part numbers for the bulbs in a post a few pages back. My local Autopro had the stop/tail and indicator and Autobarn had the reverse. All up, cost me just under $100 for all three plus bonus resistors (that I didn't use), but I get trade price however.
K-BAGZ
De Plane! De Plane!
Far North QLD
And..... This arrived today.
Also, since I have ordered new belts and upon further inspection of the accessories I have found that the AC idler pulley is a bit fingered. So have ordered a Nuline pulley kit to coincide with the new belts.
Nuline part numbers as follows:
AC idler/tensioner - EP025 Flat steel x 2
Drive idler - EP024 Flat steel
Drive tensioner - EP026 6PK groove
K-BAGZ
De Plane! De Plane!
Far North QLD
AC belt spat off as I drove into the driveway after work. Not happy, but I can deal with no AC until my belts and pulleys arrive. Not going to bother flipping it to change direction, I don't want to risk causing possible damage if it were to spit again.
Removing and installing belts on a hot engine isn't too fun either, but I'm used to it.
Trayner
Gangsta Hundy
Have fun with the t50 ? bolt on that one , its a real bitch to remove if its never been removed . I just ended up welding mine to the bolt to remove it as it kept rounding out the bolt .
