Well, I have some bad news and some good news.
Bad news: So I do an underbonnet inspection every weekend before I detail the car. Checked everything at my parent's place, all ok. Drove 4mins down the road to my place and popped to bonnet to start detailing. The moment I lift the bonnet, I find that the main accessory belt has torn a rib off and ripped a hole in the bonnet liner. Upon a further in depth inspection, it turned out to be the harmonic balancer had come loose and had begun pushing forward from the crank, putting the belts out of alignment.
Good news: I removed the OTR and thermo fans to get a good hard look at the balancer. The bolt was just off hand tight,
so lucky I found it before it had come off entirely. Would have caused major front end damage. Now, what absolutely pisses me right up the wall was when I removed the crank bolt, I found ANTISEIZE on it! ANTISEIZE on a crank bolt! I cleaned it up, inspected it for stretching, all was good in the hood. I then cleaned the crankshaft bolt hole, balancer and put some 277 red loctite on the thread and 515 master sealant on the bolt head and torqued in back up. Started the engine, got it to operating temp and gave a few stabs in the high revs then shut it off, then checked the tension on the crank bolt and visually keeping an eye on alignment when the engine was running. I also marked the crank bolt with a white marker pen for later inspection down the track, but I will now order an ARP crank bolt to put in because the GM crank bolts are one use only being torque to yield. Lucky the current one fitted is ok.
So now the Clubby will sit until all the parts arrive. I'm pretty bummed out, but also happy that I caught it when I did.
/end rant.
