4l60e gears come and go
gtrboyy
vt ss & lc gtr
Send it back if still under warranty..either going into limp mode or more than likely something on it's way out alre
no1butmeau
54
brassall
holden vx ss twin turbo
It was a cash job 1200 no warranty I've got trans pressure gauge being connected to see what it's doing
lout
60
Langwarrin Victoria
sounds like it may just be low on atf, i assume you mean dex 3
or is it school holidays
check levels with engine warmed up and running
Immortality
Staff member
Sth Auck, NZ
Definitely something wrong in the box. Low fluid would be the first check. Definitely should be Dex III trans fluid. If it happens again, try shifting to manual first and see what it does.
_R_J_K_
Zenki S14
Maybe that's your issue. Really get what you pay for with automatics, strong boxes (or even the stock ones) really can't have corners cut.
Got it running through a massive trans cooler at least?
BlackVXGTS
Melbourne, SE
From 4L60e common problems. Since your trans is OK when it's warm, maybe the pump is only partially failing.
21. No movement in any gear: pump failure, or total loss of fluid. R&R, or refill pan and find the leak. If out of fluid, avoid running the engine until the trans is refilled to avoid pump damage. To check for pump failure, check fluid level with the engine off, then start the engine and recheck fluid level. If level does not go down when engine is running, the pump is broken.
R&R = Remove & Repair (or Rebuild) = Transmission must be removed to fix the problem and may have to be rebuilt or replaced.
gtrboyy
vt ss & lc gtr
Check fluid level & colour.
If it smells burnt....
cash job no warranty 4l60e = pain
