sydsider
- Jun 24, 2022
- 141
- 40
- 28
- Age
- 58
- Location
- Sydney
- 08 VE Omega
Well there you go. The 4L60e fitted VE have a tens dipstick. If only they did that on the others.
VEs generally don’t have dipsticks. Fluid is checked via an inspection plug in the top of the pan.
Looks like the low spec models had a dipstick early on in production.
Top of the pan is interesting
I found your reply to a post when i was checking out the Low vis business and found this from you in 2018.6 litres is waaay to much.
Should be about 4.5 from memory. Just go by what the dip stick says. It's either wet or dry. There's no half wet, and there isn't 2 levels.
Out of curiosity which fluid did you use? Please don't say low vis!
Yep, I put LV in my VE and it started slipping... so I drained it and used FS instead and all good.
Whats the FS for future reference?
