SuperJIVE
- Jul 26, 2022
- 15
- 6
- 3
- Age
- 26
- Location
- Melbourne
- VZ SV6, VE SV6
Hey all, I've been having this issue with my 5L40E for a bit now and was kinda stumped on it but just found this post from 2013 and wasn't sure if i should necro the thread. I'm having the same issue with my trans atm where shifting in and out of 5th is hazy, sometimes shifts fine but a lot of the time dumps it both in and out of 5th. When shifting with paddles in active select it shifts smooth as but back to normal if you put it back in auto shift. Long story short trans got run with low oil for a while till it started making noise so i flushed it twice and put in a bottle of lucas trans additive which helped noticeably. 1-4 are normally smooth as now but there is an occasional hiccup in the revs at high rpm in 3rd or 4th (can't remember which, doesn't happen often). Have also heard that it could be solenoids or possibly valve body, I thought i might've buggered the clutch pack but it'd surely be playing up regardless of active select if that was the case. Any help would be legendary, thanks in advanceHey guys, I've got a VZ SV6 commodore sedan with the 5L40E auto gearbox installed, everything was running perfectly up until about 2 months ago where i noticed the gearbox started to 'clunk' while trying to change from 5th to 4th while doing around 80km/h and using medium throttle, it continues to 'clunk' until giving it heavy throttle which seems to force it to change down gears, it doesn't do this while using the active select to manually change gears and works flawlessly, have been doing some reading about it and think it could possibly be the shift solenoids. Has anyone else encountered this problem or knows anyone that has?. Any info would be muchly appreciated. - Cheers
