vxcalais_01
- Jul 18, 2006
- 1,355
- 42
- 48
- Location
- Melbourne
- VX V6 Calais 3.8 2001
I Had a brand new Hyundai I30 & done the first oil change at 7,500kms & used a full synthetic 5w/50 which was within the specs that could be used in that motor & after a 1,000kms there was a rattle in the motor so i cahnged back to a full synthetic 10w/40 & it stopped only to return a 1,000kms or so later so in the end it went back to Hyundai for warrenty & long story short it had worn the bearings out & the piston pin holes in the piston causing this rattle.....
Conclusion..... A Standard spec oil is more than enough for a street car, there is absolutly no need to exceed any standard specs unless it is not standard, simple as that....
Sounds more like a fault than a Oil issue. Oil barely has trouble getting to the bearings and pistons. If you said to me due to small galleries it couldn't reach and lube the dual overhead camshaft etc,maybe but 5w50 would be the highest you would wanna use in a dual overhead cam. Elf made the Excellium 10w50 for factory WRX which are overhead cam. Same as Corollas, they even allow for 20w50. In such a short time, it would definately be a factory fault. What happened to your I30, they are a very good car.
