Darren_L
- May 2, 2009
- 1,872
- 68
- 48
- Location
- Toowoomba, Qld
- VH SS
Hi all,
just joined up. Here's my ride.
I bought it about 5 years ago, as a stock VH SS (4.2L 4spd). It was sold to me by a dodgy sort of guy who had performed a quick paintjob on it and obviously wanted to make a few bucks. It was wtock right down to the original SS 14 inch Cheviot alloy wheels. Engine, gearbox & suspension was stuffed, so I basically drove the thing home on a trade plate, parked it in the garage and pulled it to pieces. I replaced fairly much all of the interior - including recovering the dash(previous owner had removed the SS door trims and seats, fitting beige..... door trims & seats..... great match to the remaining SS dark claret dash & roof lining.... . Replaced all the suspension, built up a warmed 304 out of a VR coupled with a T5 and dropped it in.
It now has a HDT Grp 3 bonnet scoop fitted to accomodate the Trickshift manifold, I also plan on fitting a matching Grp 3 rear boot spoiler when I get the chance.
Model: 82 VH SS Commodore
Engine:Holden EFI 5.0L, balanced, ACL pistons, Crow Cam/valve springs, Rollmaster double row timing chain, Y/T roller rockers, Trickshift TTB intake manifold, Bosch 044 fuel pump, Kalmaker SP3 ECU, tuned by Paramount Performance
Gearbox Borg Warner T5 5 speed & RPM H/D clutch
Exhaust: Pacemaker headers, 3 inch single exhaust, resonator
Suspension: Koni adj shocks f&r, lovell s/l springs, whiteline sway bars, kmac camber adjusters, nolathane bushes, Pedders adjustable panhard rod
Brakes: VN Grp A 330mm front rotors & twin spot calipers, Grp A ventilated rear discs & calipers
Rear Axle: 10 bolt Salisbury 3.08 LSD
Wheels: 16x7 'Walkinshaw', 225/50/16 Toyo R1R Proxes tyres
Interior: recovered dash, re-trimmed velour door cards and rear seat in original 'dark claret', VS front door speaker pods, Cobra Daytona front seats, Momo wheel, electronic VDO speedo painfully....integrated into instrument cluster
other mods: VN 80L fuel tank, oil catch tank/seperator, fuel surge tank, VS steering rack & k-frame, battery in the boot
power: 275 rwhp
future mods: cylinder head port job, 3.36 diff gears with true-trac centre
power: 275 rwhp
