RevNev
- Dec 9, 2020
- 2,585
- 3,502
- 113
- Location
- Adelaide
- VF II SSV Redline Ute
That makes sense! It's like mechanical camshafts and solid lifters in a 308, rev it up and they'll spin big ends despite high oil pressure shown on a gauge. What happens there, is the effort of pushing the oil through the filter at high revs, opens the pressure relief valve prematurely. The gauge is reading the oil pressure at the filter housing not the oil gallery.Subaru did this on the early Tribecas. The spin on filter makes SFA difference to fluid filtration as the majority of the fluid bypasses the spin on filter anyway as you risk fluid starvation by forcing it all through the spin on filter. They deleted it on later models of the Tribeca.
Harry Firth from HDT devised a mod for the L34 Torana where you port the filter housing and block the filter bypass valve to redirect the oil around the pressure relief valve so it's open to oil gallery pressure instead of filter pressure and fixes the big end failure issue at high RPM. I bought an oil pump from Ian Tate around 1992 and found the trick! Prior to that, we'd use high volume oil pumps and shim the pressure relief valves and fill the rocker covers up with oil blocking the breathers. On the circuit a few laps in, the catch can was full of oil spraying it around the engine bay!
