Has anyone seen mold in their Air Conditioner? I wouldn't be spraying anything into the HVAC unit unless you could be certain it had mold growing inside.
Years ago, back in the days when the VH commodore was new, the windscreen plenum didn't have a decent mesh screen on it so leaves could make their way into the hvac system where the fan would shred them and they would clog the drain vent. With the aircon in use, water could start to pool up within the system. Usually the fix was a wire would be pushed up the drain tube and wiggled which would be enough for the muck to flow out, then a new screen mesh would be installed in the plenum at the base of the windscreen to fix the problem. In some cases, mould would take hold within the system and the wire wiggle would do nothing so the complete system needed to be pulled out and manually cleaned, which if memory serves correct was a dash out affair. Sad part was Holden never took full responsibility or ownership of the problem as it was handled on a case by case basis.
Some people had this problem (of Holdens making due to the poor design) fixed via "a guesture of goodwill" while others had to pay for the cleanup and fix. Some paid huge dollars for the dash out fix... Luckily in my case, my VH was not badly impacted and Holden did their goodwill thing as it was just a bit of a wiggle and poke before flushing some fluid and finally they emptied a spray can of some aircon evaporator cleaner through the system before finally adding a screen filter and it smelt nice afterwards so couldn't complain.
However, back in the day there was a small stink about this and the problem even made it into The Age (way off the front page) but it was before google so haven't been able to find a reference....
So yes, mold can take hold as it simply depends on moisture, heat and mold spores which float in the wind. Having a blocked HVAC drain tube with some aircon use results in water in the system, then parking the car outside for a few days during a warm summer is all it takes for a mold outbrake to occur and you may not like the smell of the car when you next hop in.
Luckily usb/android phone styled endoscopes can be sent down the vents to have a look if there is any mold issue within current sysyems. Such endoscopes are cheap and range from $10 to $20 on ebay - they also have lots of other uses
Anyone tried a mould killer spray like Exit Mould. I have used in the house and it did the job. Cleared up the mould on ceiling, has a mould retardant ingredient. 2 years later, still good.
They might make something for Aircon systems.
Exit Mould uses Sodium Hypochlorite and the bottle states "test in an inconspicuous area before use" (which may just be mumbo jumbo for their legal protection). But i'd want some assurances that whatever chemical is used, it will not kill the plastics down the track. As such, it's only the vehcile manufacturer that could provide such assurances... and then they would sell something with maybe Sodium Hypochlorite as the active ingrediant and charge $60 for a bottle
