HB is fine and so are the pulleys n belts, they are quite smooth n quiet.
You have either a (1) rpm rattle coming from oil pump spring/piston next to HB .... or..... (2) a rpm circular hitting/ticking noise coming from behind HB points to crank angle sensor/fittings ....or ... (3) rpm circular timing chain hitting worn chain damper echoing sound in timing cover case.
Hope that helps, you can find the obvious issue but involves a strip down of the HB/belts and or chain timing cover case.
Well he got clues to his posted question The answer lies when the job is done not just by thinking about it onlineIts none of what you mentioned, it's the balancer.
well they way you wrote it sound like maybe ????thumbs off if i tried to turn it when it was running-lol
Is there any companies that sell them at all or just ebay?i am not having much luck looking.
i am in hobart so is merv gray a shop?i can wait as well.thanks again.If you want one same day it will be Repco, if you're in Launceston and can wait until the next day it will be Merv Gray, if you can wait a week it will be eBay. The latter is in order of cost, highest to lowest.
