Any idea what this noise is
Flaggers
27
S2 VF SS
Only just started happening as of yesterday, any ideas? VF S2 LS3.
stooge
wa
Turbo Alpaca
hard to tell but it could be a pulley or water pump.
you can probe around the pulleys and water pump with a long handle screwdriver to your ear if you are capable of working around a running engine.
if not buy a stethoscope to do the job.
if you find it you will know it by the sound.
stooge
wa
Turbo Alpaca
Any rough idea of how much I’d be looking at for a new water pump + install?
400 bucks on ebay for a genuine pump and you will need coolant.
they are easy as to install, when i did mine i did the belts too.
if you get a mechanic to do it i would expect around 2 hours to be charged.
i would probe it first to make sure it is the pump before changing it.
Ron Burgundy
NSW
VF II SS
Don’t wanna sell it but getting very close mate.
Probably $600 ish installed :(
Skylarking
123
Downunder
Commodore Motorsport Edition
I think it’s Holden’s equivalent of the following
vr304
Auckland, New Zealand
2007 ssv manual
I’d take the drive belt off and rotate the idler pulleys and water pump by hand you should be able to feel which one is a bit rough to turn
Flaggers
27
S2 VF SS
Any guides or quick rundown on how to change it over? Haven't really worked on cars before other than doing oil change/spark plugs but I'm pretty eager to learn and do stuff myself where applicable.
