Are Ex or Current Cops cars equipped with a modifed chip?
davway
Warrnambool
WK LS1 Statesman
goes into which ever fuse controls the interior lights.
remove the standard fuse and plug the wire in.
cpbait
vy ss commodore 5.7ltr
oh ok, sweet as i'll try it tomorrow and see what happens
cpbait
open your fuse box under the dash, and plug the harness back in - youll know what i mean when you find it.
you should now have the extra light controls working.
your a dead set legend, i did what you said and the map lights work :thumbsup: lost my interior light operation though, pressed the switch behind the window switches and the interior light works too now and if i don't want it too work i just press the switch in and the map lights still work so all 3 now work :D
davway
Warrnambool
WK LS1 Statesman
push the one on the dash and it will kill all interior lights (glovebox included).
HIROLLA
vic
VS SIII CAPRICE
theres a supercharged rodeo light blue with police stickers thats always around kings cross
cpbait
that the headlight switch?
or maybe the toggle switch i took out that was disconnected.
davway
Warrnambool
WK LS1 Statesman
unless they stopped using them after the VX, there should be a switch to left of the steering wheel that looks like this:
push that and it will turn off all lights inside the car.
cpbait
nah there isn't but there is a bigger version of that on the center console which cuts out the interior light, didn't have lights on when i pressed it, but if it doesn't all good.
capitalgainz
Banned
adelaide
vt s2 berlina gen3
um, technically. the v8 vn-vs cop car was fitted with a v8 185 kw tune?? i dont know if the engines are the exact same as the standard 165 v8, the cop cars were standard commodores equiped with all the ss **** except the body kit. although i do know that the v8 cop cars also had better fuel econemy cruising its possible but i know they are all 185kw hsv tunes
STEALTHY™
So Wet For You!
SA - The Roadworks State
165 VN motors are the same all the way to VS motors. The only difference was bolt on stuff like exhaust, and tune, which gave the higher output.
