meetone
- Jun 28, 2012
- 4
- 0
- 0
- Location
- Canberra
- 98 VT Commodore Acclaim
G'day,
Wondering if anyone has had similar faults to me and asking for a bit of advice before I get quotes for a rebuilt box.
The car has 195K's on it, and as far as the history goes I'm not sure if it has ever had the tranny replaced - It's just the stock 4spd Auto.
Symptoms are:
When cold, shifting from R to N results in an audible cluck
When cold, if I shift fairly quickly from R to D, the car will stall (you have to engage N, wait a few seconds, then select D)
When cold, first gear appears not to engage properly, and will rev the motor to around 3K RPM at 20 KP\H until second gear engages
When hot, and the hammer is down, third gear completely disengages when the car tries to upshift into top gear at around 4.5K RPM(i have to back off, wait for 4th to engage, then continue on)
I completed a transmission service about 10K's ago using a coopers filter and DEX IV oils, I was going to do yet another tranny service this weekend to see if it will help. There wasnt any abnormal metal pieces or anything nasty in the pan, although the oil in it was disgusting.
As a side note, I've checked all the error codes on the dash and there was nothing to report (looking for wheel speed sensor faults or anything similar). About 15K's ago, I did recieve a TPS over-voltage error so I replaced it with a new unit from Auto Pro. When the dash warning light came on, the car did pick up in revs when cruising quite significantly.
If anyone has some advise on where to go next, that'd be great!
Cheers.
Symptoms are:
Cheers.
