LucasTa96
- Oct 8, 2022
- 9
- 0
- 1
- Age
- 27
- Location
- Beverly Hills
- Holden Commodore VE SV6 2007
Hi everyone, i have Holden Commodore SV6 2007 automatic transmission. My car takes a few seconds delay to switch to drive only. On a cold run seem fine but when the engine warm up, it sometimes revs high to start moving from stop and the car shakes, sometimes it takes off just fine. Always difficult to go up hill. There are also jerking/slipping when gear change while driving. Got engine code to: P0700.
My solution for this is when i stop the car, i switch to selective gear so the car can be at first gear, the car takes off just fine but a bit high rpm. When it starts moving, i switch back to drive and continue driving normally. That way, the car less likely to shakes. Also noticed that when i use selective gear, i can only do upshifting but not downshifting. It can only downshift when the speed is drop.
I bring the car to transmission specialist, was told the fluid level was low and the damaged had already been done and need to be rebuild (based on how he feel when driving the car). The leak is from the pan so must be the seal worn out. For now, i refill the fluid with new filter and seal with Lucas transmission stop slip. The car run a bit better but still difficult to take off and the car still shakes sometimes. Switching between selective gear and normal drive seem help a lot when taking off and less likely to shake. Still couldn't downshift with selective gear. And the code is gone.
So my question is: will the problem is actually from the clutch, flywheel, transmission solenoids? Or it really from the gear box itself that need to be rebuild?
I drive my car every day to work and long driving with heavy load on it.
Thanks
Thanks
