battery life
lmfvf2ssredlineute
59
vf2 ssv redline lmf ute
i posted this some time ago and wondering how are other members going with there car batteries
i bought two 2017 redlines new and both batteries are still going strong
my ebay load tester says both battery's are ok
5 years is good for a car that runs lots of power draining stuff
anyone with a 2017 car replaced one yet
these ac- delco batteries seem to be good quality and worth replacing with same
losh1971
North Tas
VE Series I SS Ute
Those Delco batteries get good reviews. May help that they no longer cop engine heat too.
Ginger Beer
Dunnydoore
Throwing on a quality multi stage trickle charger on during "down time" helps alot, especially during colder months
My bike lives on a trickle charger, and the car has it's own hooked up every so often or if the car is going to sit around unused for a while
I have connectors like the image below wired to the batteries of the car and bike for ease of quickly connecting my 7 stage chargers
Anthony121
VF SSV Redline MY17 & VF Director
I purchased two cars in 2017 like yourself. The one I drive every day is fine still but in 2020 I replaced the battery in my Director. A mate also has an SS built within a week of my Director and his battery died too.
My first VF Calais V was sold after 4 years with original battery. my VE Calais sold after 6 years with original battery. The location of the battery in the boot helps prolong the battery's life.
losh1971
North Tas
VE Series I SS Ute
I throw the charger on mine every couple of months, just to ensure every so often it gets a full charge. The batteries in the VE and VF take a while to charge and require the right type of charger, one capable of fully charging a calcium. Mine takes about 14-16hrs to reach full and I drive it most days. A small CTEK would probably work. Mine is a Repco 8amp and takes forever, a 16amp would be better suited I think.
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
The biggest killer of car batteries is heat. The VE/VF series Commodores having the battery in the boot is already winning half the battle against entropy.
I never had a battery in my old VE SV6 last less than 7 years. Every other car I‘ve ever owned would be lucky if it made 5 years out of a battery because they were mounted in the engine bay.
wetwork65
A wet business
VF SSV Wagon & VF SV6 Wagon
My SV6 is from 2014. It gets started several times about every second day (shopping etc), less often during the height of Covid.
I noticed some deterioration in the battery in early 2021 and bought a Ctek 5A charger.That kept it alive for another 6 months.
7 years out of the battery.
Replaced with the V8 rated AC Delco battery. The starter motor rotates at high speed every time I turn the key. That is my indicator of stored electricity quality (calibrated as oomphs per second or something).
My other car, the SSV which is a bit newer starts up once a week on average. It had its battery changed at much the same time.
I give it some Ctek love every couple of weeks.
It's starter motor also rotates at a high number of oomphs.
hjtrbo
Donating Member
FG XR6T / HJ Ute / VF2 R8
Yep, I'll add to the discussion. Late 2015 LSA V8, Still on the original battery. Never used a maintenance charger on it. It's the quality battery and the 'smart' alternator that keeps them alive for so long.
